I'm sure its possible, but has anyone done it and what does it entail? I have a 96tt Auto completely stock and want to make her scream a little. So i wanted to change over the harness from my 96 to a 95 basically obdII to obdI and of course swap the ECU to a 95 and add vvt, cams, sprockets, and solenoids I have understood that i will need to rewire or change the TPS and coolant sensor other than having sensors that will not be used is there anything else that i need to consider? I really hope someone out there has done this!! Thanks in advance for everybody's help!
96 ECU to 95 ECU harness swap? - speedysaenz18:49:38 04/19/11
